2006 Baja low beam headlights are always on is this correct?
SCOOTER
Post by SCOOTER »
Hi first my low beam headlights are always on when I'm driving but if I pull up the emergency brake it goes off. Is this correct is this normal for the Baja 2006 sport. I did put in LED bulbs that do flicker a little bit but they were doing the same thing before with the original bulbs always low beams are on pull up the emergency brake it goes off. A second question is the engine only has 75,000 Mi and it does have a bad piston slap a person told me that it's okay I'll run another 50,000 MI but with Subaru ever help me with this? Thank you a newbie Mr scooter.
greymud
Re: 2006 Baja low beam headlights are always on is this correct?
Post by greymud »
Those are daytime running lights.
05 NA 5MT
And yes, they are SUPPOSED to be on, and turn off when park brake is set. There is a modification you can make to have them not automatically be on. Dennis
SCOOTER
Post by SCOOTER »
Thank you.....
