Identifying rear axles
new_2_soobaaroo
Post by new_2_soobaaroo »
Help!
I pulled the rear axles while preparing to change out the (very rusty & broken) rear subframe. I didn't realize that they were different part numbers at the time and got them mixed up in the process. Now I'm not sure which is left and right. Is there a way to tell them apart? Vehicle is a 2005 turbo with 5MT
Re: Identifying rear axles
My understanding is, the shafts are the same, with the exception of some flutes cut into the stub that inserts into the differential: they're mirrors of each other, and they're to channel the oil back into the differential, to help prevent leaks. Therefore, looking at the shaft, when the vehicle is moving forward, the oil that sits between it and the outer seal should be channeled back into the diff, similar to how directional tires channel water to the outside away from the center.
Not sure if that's true, but it seems to make sense to me...
I tried looking at https://parts.subaru.com/a/Subaru_2003_ ... E6CBA66CA1 to see if they had diagrams of each, but they just indicate which part numbers are for which side. You could try searching for photos of those part numbers to see if someone posted actual photos.
20Baja06
Post by 20Baja06 »
Did some searching for you. Per NAPA:
Right Rear - flutes curve away from view.
Left Rear - flutes curve towards viewer.
So that, when placed end to end, they would be directional and perfectly in line with what @anarchy1024 stated.
new_2_soobaaroo
Thank you for the assist. Will come in useful when it comes time to put it all back together. Gotta fix the rust first, though.
new_2_soobaaroo
Well, when installing axles again (finally) I couldn't see any difference between them, as the flutes were cut the same on both. So just cleaned them up and put them back in. Hope they will be happy. New gear oil in the diff, and we will see. Now I just need to get all the suspension hardware torqued and have an alignment done.
Right after I figure out why it won't start anymore. I had the fuel tank out to weld up a section of frame, and now the fuel pump doesn't seem to be running. Haven't spent much time yet trying to diagnose the issue.
