Fireball857
Related the fuel lines under the intake manifold, hoping to get rid of a fuel leak. If that doesn't do it, I'll be replacing injector seals. Tomorrow, it's getting installed, along with a new turbo, as the older one has a nut bouncing off the impeller for probably 50k miles.
- PXL_20220226_184645406.jpg (3.05 MiB) Viewed 630949 times
- FB_IMG_1646456035694.jpg (141.33 KiB) Viewed 630949 times
Ugh I gotta do the same to my NA... Every couple days I get a whiff of fuel on startup, and sure enough if I look it's a little damp under the rubber fuel lines...
judahsiefert79
Oh yeah
Bulldog-Baja
Here's what I've done to my Baja.
Original Post Here: viewtopic.php?p=23944#p23944
Link to Photos Here: https://photos.app.goo.gl/NnPRs18VahQ8yWZ66
WHEELS / SUSPENSION / DRIVETRAIN & SKIDPLATES:
- Method 502 Rally Wheels (5) * Yes, a full-size spare fits underneath!
- Yokohama Geolander Tires (5)
- ADF - Anderson Design & Fabrication 2" LIFT
- KING 05-07 BAJA Springs
- Whiteline Control Arm Kit - Front & Rear
- Whiteline Front endlinks & sway bar
- Primitive Racing Front Skidplate (with Fumato Valve & Lever Lock); https://get-primitive.com/skidplates/12 ... and_fumoto add_oil_holes_fumoto_valve_and_extra_lever_lock_52_50/header_spacers-add_special_length_h/thickness-3_16_rally_tough
- Primitive Racing Rear Differential Cover; https://get-primitive.com/skidplates/15 ... cover.html
- Primitive Racing 4EAT Auto Transmission 1/8" Aluminum Skidplate; https://get-primitive.com/skidplates/15 ... plate.html
- Subaru OEM driveshaft (there was a vibration, so replaced and took care of it)
ENGINE & MORE:
- GrimmSpeed Top Mount Intercooler (TMIC); https://www.grimmspeed.com/top-mount-in ... 04-08-fxt/
- GrimmSpeed TMIC Y-Pipe Kit; https://www.grimmspeed.com/top-mount-in ... it-subaru/
- GrimmSpeed Ver 2 Turbo Heat Shield; https://www.grimmspeed.com/version-2-tu ... i-lgt-fxt/
- GrimmSpeed Lightweight Crank Pulley; https://www.grimmspeed.com/lightweight- ... j-engines/
- GrimmSpeed ELECTRONIC BOOST CONTROL SOLENOID 3-PORT; https://www.grimmspeed.com/electronic-b ... -9-13-fxt/
- GrimmSpeed Air Oil Separator; https://www.grimmspeed.com/air-oil-sepa ... i-lgt-fxt/
- Torque Solution 2.4" Turbo Inlet Hose (Black); https://www.torquesolution.com/ProductD ... K&CartID=1
- COBB SF Intake; https://subimods.com/wrx/2002-2003-wrx/ ... 8-fxt.html
- Mishimoto Radiator + Upper & Lower Silicone Hoses
- all belts & hoses replaced
- Subaru Block Heater
- Extreme Power X2 battery (19-Jul-21)
- Torque Solution Billet Battery Tie Down
EXHAUST:
- GrimmSpeed Catted Downpipe; https://www.grimmspeed.com/grimmspeed-c ... x-sti-fxt/
- GrimmSpeed Up Pipe; https://www.grimmspeed.com/up-pipe-wrx- ... -lgt-obxt/
- Custom, 3" cat back exhaust w/Magnaflow can (fantastic sound - not too loud)
ADDITIONAL:
- Snail Performance Pro Tune - Open Source (after above-noted parts installed); https://www.snailperformance.com/
- Kaizen Lighting Custom HID headlights
- Raptor Bed Liner (as seen in photos, entire bed disassembled, with each part sprayed separately) + wheel wells coated
- camper shell, hood & roof wrapped in Avery Dennison Vinyl (professional installation)
- 2" trailer hitch (for bike rack - not indented for towing)
STEREO / ALARM:
- Dynamat, sound dampening installed on all four doors
- Pioneer stereo with navigation & Sirius XM Radio
- new backup camera
- Alpine R Type component speakers (front doors) & coaxial on rear doors
- Alpine KTA-450 Amp
- Viper remote start & alarm
- hardwired for Blackvue front & rear dashcam (OPTIONAL to purchase actual cameras)
- hardwired for Escort radar
PLEASE DON'T HESITATE TO CONTACT ME WITH ANY QUESTIONS!
THANKS
ENGINE & MORE:
EXHAUST:
ADDITIONAL:
STEREO / ALARM:
- new backup camera
THANKS
Hey gang. Anybody know what these rhomboid shaped pockets are for in the bed of the bajas? I figure such a dedicated space must have a deliberate purpose. I went ahead and built a bed divider that sits nicely in the rectangular spot within the rhomboid. It worked great in my 19 Ranger and I was able to modify that one to fit the Baja. I also did a brake fluid flush today on the Baja. Pedal is way better now. Not so spongy.
Anybody done a complete brake replacement. Hoses and calipers and rotors?
- 56381F8E-2881-45F5-B121-42D4BA872E73.jpeg (3.38 MiB) Viewed 629915 times
- F14C7AED-B602-4A76-BB42-11B064F24260.jpeg (3.11 MiB) Viewed 629915 times
baja_gernaut
The best upgrade that can be done to the Baja are brakes with 4-2 pots. I hated my OEM feel and once I had them installed, the Baja didnt nose dive anymore. Ive done it all to the Baja since 2008, WOW
Leon in PA
I installed Sport Activity Lights (Hella 500s). I bought a partial used set a while ago and had the brackets remanufactured.
I am selling the brackets $90/Set shipped
[img
287771964_811869799800442_4878259760197885577_n by Leon in PA, on Flickr][/img]
[img
Sport Light Bracket 2 by Leon in PA, on Flickr][/img]
[img
287771964_811869799800442_4878259760197885577_n by Leon in PA, on Flickr][/img][img
- Knotwright
Added some goodies over the last few weeks. New tires TOYO 215/70R16, New dash pocket with 3 switch sockets, front grille light bar and custom trailer hitch.
- IMG_0052.JPG (4.45 MiB) Viewed 629243 times
- IMG_0047.JPG (6.76 MiB) Viewed 629243 times
- IMG_0051.JPG (4.66 MiB) Viewed 629243 times
Any more info on that pocket with the three switches? (I would like to add something like that)
I'm going to guess that came from an Outback because of the rear wiper switch. What is that strange symbol on the center switch? Dennis
This is my first post on this forum. I'm currently fixing up a project 2005 Turbo. Back in the day I bought a brand new 2003 non-turbo. It got wrecked 3 years later on I-95 so the car never got old with me. I'm glad to be back into a Baja and the turbo is fun. This car has 110k miles, came with a vinyl corporate wrap that was a pia getting off. A dent in the passenger side front door, 2 blown front speakers, bad axle on the front passenger side, bad water leak in the front passenger side, musty smell from water, torn front bumper, 4 slashed tires and a dead battery. I have been ordering various body trim parts that were missing both inside and out. Picked up a bed extender last week. The rear bed cover is mia but I do have the hardware for it.
I got this thinking it would be a fun project for me and mu son to work on so he could drive it in his senior year of high school. He hated it and bailed on me so I gave him my 2010 Ford Escape and I kept the Baja for myself.
New front speakers because I need music.
My first attempt at a paintless dent removal. Ended up knocking it out from the inside but the door cross member was in the way. Not perfect by any means but better.
- theluckyone17
Long story short... I traded my Baja in a while back, towards an '09 Tacoma. Guy who bought it from the dealer found the FB group card I left in her, and reached out. We kept in touch. She blew a headgasket about an hour south of me in August. I bought her back. Just finished up the headgasket replacement. Drove her about forty minutes south today to pick up some used rims, then took the meandering and scenic route back home. Coolant tempts stayed constant, and she cleared all the emissions OBD2 tests. Once I get new tires on the rims (dropping them off Tuesday), I should be good to get her inspection current.
Onyx: 2006 Baja Sport
theluckyone17 wrote: Sun Oct 16, 2022 4:33 pm Long story short... I traded my Baja in a while back, towards an '09 Tacoma. Guy who bought it from the dealer found the FB group card I left in her, and reached out. We kept in touch. She blew a headgasket about an hour south of me in August. I bought her back. Just finished up the headgasket replacement. Drove her about forty minutes south today to pick up some used rims, then took the meandering and scenic route back home. Coolant tempts stayed constant, and she cleared all the emissions OBD2 tests. Once I get new tires on the rims (dropping them off Tuesday), I should be good to get her inspection current.
Heck yeah that's awesome!
