Catless Down Pipe.
Kras700
Catless Down Pipe.
Post by Kras700 »
First off im new here just bought my 2006 Baja turbo on 1-28-13 with 70k on it. I was wondering about replacing my cated down pipe with a catless one. Will this through a check engine light? What one will fit on my 2006 Baja turbo? I will be replacing the mid pipe cat with a high flow cat also. Thanks hope to hear from you soon.
tomato_88
Re: Catless Down Pipe.
Post by tomato_88 »
I am 90 percent sure that it will throw a Cel. I believe there is a fix but you would have to Google the details. Try 2.2 ohm resistor fix.
Kras700
Post by Kras700 »
Hey thanks i will look into that. I might just get a high flow cat for the down pipe and the mid pipe. I have welded a few of them on my self so it probably wouldn't be much of a problem.
