SKID PLATE INSTALL
SKID PLATE INSTALL
I am installing an after market front skid plate and having trouble removing the factory plastic skid protector on my 2006 BAJA, I removed all the bolts but can't get it off because the side clips or bolts are holding it on. Any ideas on how to remove these side clips?
- anarchy1024
Re: SKID PLATE INSTALL
I think it pops out with enough force. Honestly, mine disintegrated and fell off by itself so I didn't have to remove it...
Bam1234567
Just to make sure, how many bolts did you remove? There are 3 12mm up front, 2 12mm in back, and 2 10mm on the side (one on each side) up pretty high. After that there are 2 clips in the font but they let go with relatively little force.
