RESOLVED - Forester Head Unit with built in 6-Disc Changer in Baja?
I found a head unit from a 2004 Forester at the salvage yard and they were having a sale so I picked it up for $15. Looks to be in great shape. My Baja has a single disc head unit that works some of the time.
Pretty straightforward question: has anyone ever installed Forester head unit part number 86201SA110 in their Baja?
Never hurts to ask before tearing into it and finding out.
Thanks for any help!
- anarchy1024
Re: Forester Head Unit with built in 6-Disc Changer in Baja?
I just checked the wiring diagrams, and they appear compatible. I say 99% sure it should work. I'll post the wiring diagrams shortly.
- anarchy1024
Some of the wire colours are different, but the pin numbers are the same for each function. If the connector fits, you should be good.
- Forester Radio Wiring.jpg (296.78 KiB) Viewed 28429 times
- Baja Radio Wiring.jpg (350.53 KiB) Viewed 28429 times
I appreciate the help and the quick reply! I’ll be honest, I was asking more from the standpoint of physical fit. I know I’ll lose at least one of the cubbies to fit the larger unit. Past that, wanting to know if it mounts the same or if I’d need to modify anything or if the center console trim fits with the unit.
But step 2 is the wiring and I agree it looks functionally the same. So I’ll give it a go the next time I get a chance to spend some a few hours in the garage.
Thanks again!
Thanks again!
- anarchy1024
Ah, okay, fair enough.
It still looks good, because there's a recessed "lip" around the faceplate that looks the same as the 2002 Outback 6-CD changer that I have (which uses the same plastic bezel as the Baja). If the head unit face occupied the full width, it would foul on the bezel or need to be recessed behind it; this looks like it should be good.
You could compare photos of the 2002 Outback 6-CD changer with cassette deck, which does physically fit in the Baja properly, and see if the mounting holes and other characteristics are the same.
But to answer your question, sorry, I don't have first-hand experience with this specific head unit. Evidence suggests it should be a direct swap, though, with no modifications necessary.
- Screenshot_20231105-204146~2.png (1.06 MiB) Viewed 28426 times
Is your photo the Outback unit?
Here’s the Forester one.
Either way, I appreciate the response. I haven’t studied the unit much yet so unless I get a firm answer between now and when I get time, I’m going to give it a try. From there I will report back.
- anarchy1024
My earlier photo was one I found online for the part number you posted.
The 2002 Outback one looks like this: https://www.ebay.ca/itm/253882952130
I just mentioned it because I saw that the one in that photo, which I hope is the same Forester one as yours, has similar design features to the Outback one that I have and know fits.
I follow you now.
I’ve been trying to compare against photos of this unit which I’m reading all over fits the Baja. The Forester one looks just a bit nicer, IMO.
Chiming back in to update that this worked out. I was initially pretty concerned with the Forester unit's mounting brackets and whether they would be compatible with the Baja's HVAC controls. Once I actually looked at it, the Forester unit's mounting brackets, like the Baja's (and like any other radio that ever existed out there, apparently), are removable.
The Baja's brackets are conveniently "universal" and aligned perfectly to the Forester unit. First picture shows the Baja's stack compared to the Forester unit with its mounting brackets. The second picture is one side of the Baja bracket mounted to the Forester unit.
Due to the Forester unit being approximately twice as thick as the Baja unit, I was going to lose one of the storage cubbies. I opted to keep the lidded cubby for a more "finished" look. With both mounting brackets and the lidded cubby in place, I hooked the unit back up to the car and reconnected the battery to give it a try -- all systems appear to be functional!
After that test, I unhooked the battery again and continued to button things up. It went nearly without a hitch. One issue I ran into, utilizing all of(4) screws to mount the Forester unit to the Baja's mounting brackets the lower, right rear bolt gets in the way of reusing the original screw (top) that mounts the Impact Sensor Unit. Specifically, the washer interferes with the lower right rear screw and prevents this mounting screw from being used. I went to my handy-dandy screw collection and pulled out a M5 x 0.8 socket head cap screw (bottom) that ended up working out. It rubs right up against the lower right rear screw but it does thread in. Final product is shown as well!
I appreciate the help on this and am glad to put it to bed!
- anarchy1024
Re: RESOLVED - Forester Head Unit with built in 6-Disc Changer in Baja?
Very nice! Glad it worked out!
