Starting a new modification. Custom Grill!
slagman
Re: Starting a new modification. Custom Grill!
Post by slagman »
Here's mine:
YBajaSteve
All-Mighty Scoobytruck Admin
Post by YBajaSteve »
looks good! I do have a few updates on mine, but nothing really to post, I should have mine done soon tho. i had some issues with paint, im trying to make it as perfect as possible... where did you get that mesh? I think it looks good.
slagman
Post by slagman »
Thanks, its actually my 2nd grill. The first attempt, I sanded it down and painted it black with special paint but it just kept chipping and looked like hell. So I ordered another grill and got the mesh from Grille Guy.com. The mesh was under $40.
Thacrudd
Post by Thacrudd »
Wow both of those are lookin good! I was considering doing this to mine but was a little afraid to go chopping on my grille though...
YBajaSteve
Well Ive had it on the truck for a couple weeks now, so heres the pics. The emblem got messed up from the adhesive i used, so illl be getting a new one. Luckily this one was free.
YBajaSteve
^^^ What do you guys think?
bajaninja
Post by bajaninja »
Awesome job!!!
PenguinSub
Post by PenguinSub »
I know I'm a lil late on this, but that grill looks leh bomb.
I was thinking about doing something like that, but I wasn't sure if I was handi-capable enough for it...
brujah2
Post by brujah2 »
I did something similar on mine, cutting out the crossmembers. I removed the center one though...I used fiberglass to bridge the gaps, and bondo to smooth it for paint.
rookrex
Post by rookrex »
I'm in the middle of doing this, what kind of epoxy did you end up using? I was thinking about going the bondo route, but your method might end up being a little easier if I can def sand the epoxy.
Also, where did you get your mesh?
Gorilla should start making some mesh grills that will bolt right on :D I know I would buy one !
PenguinSub
Snorkeled wrote:Gorilla should start making some mesh grills that will bolt right on :D I know I would buy one !
+1. I feel that kind of mod is something I can convince the wife to let me get.
starr-
Post by starr- »
Anyone got any good recommendations for a product to use to fill the cut out plastic gaps in the grill once I do this? I have played around with plastic weld stuff (came in a chalk like tube) but haven't ever tried fiberglass... There is just so much to choose from on ebay
Fiberglass for support, bondo to fill. I plan on doing this sometime. But leave the chrome trim.
sykemikeg
Post by sykemikeg »
That looks real sweet. Awesome job.
Sent from my HTC6525LVW using Tapatalk
