CVT Tranny
BrotherBroja
CVT Tranny
Anyone ever thought of swapping a CVT Transmission into their Baja? How would it compare to an STI swap? Just probing
Re: CVT Tranny
I haven't done it, but I'd guess unless you have either an aftermarket transmission management computer, or aftermarket engine management computer that can work with the stock Subaru CVT TCM, it won't work. You'd also need a drive-by-wire throttle. Of course, all this assuming it'll physically fit...
Re: CVT Tranny
CVT = even mushier and less exciting than a conventional auto.
STI swap = 6 speed manual
Why is this even a question? Seriously though, what are YOUR goals since in my mind, these are polar opposite options.
*might* get slightly better mileage after you get all the electronic controls sorted out and tune the gear ratio curve to your engine but 2mpg improvement is going to take longer to pay off than the trans will last.
BrotherBroja
Re: CVT Tranny
I figured it'd need an extensive amount of modificationsanarchy1024 wrote:I haven't done it, but I'd guess unless you have either an aftermarket transmission management computer, or aftermarket engine management computer that can work with the stock Subaru CVT TCM, it won't work. You'd also need a drive-by-wire throttle. Of course, all this assuming it'll physically fit...
BrotherBroja
Re: CVT Tranny
I'm just wondering about other tranny alternatives besides a STI 6 speed. I occasionally need to have a family member drive and hey, not everyone can drive a stickkamesama980 wrote:CVT = even mushier and less exciting than a conventional auto.
Re: CVT Tranny
So you just have the itch to spend money? Nothing cost effective to modify on a 4-speed auto, no. *Might* be able to firm up the shifts and put a manual controller but then you just dumped a grand into a 4 speed auto. You might be able to add a factory tiptronic/sport shift/ whatever subaru calls it but that'd be harness/computer swap stuff and my experience with them says they aren't worth the effort unless you really have a lot of money/energy to burn.BrotherBroja wrote:I'm just wondering about other tranny alternatives besides a STI 6 speed. I occasionally need to have a family member drive and hey, not everyone can drive a stickIs there anything to upgrade a 4 speed auto?
If it's just "on occasion" teach them to drive and tell them to suck it up. My wife has anxiety attacks about driving stick but on the occasion she's needed to drive something other than her Prius and she always surprises herself (self confidence issues so having done something before is totally irrelevant to being able to do it at the present
If it's a medical issue (missing limb, destroyed joint, etc) then you're just screwed.
