Ground Strap Question
jestermail
Post by jestermail »
Hey guys,
I was changing the plugs on my normally aspirated 2006 Baja when I located the pictured ground strap not connected to anything, laying under the intake resonator box. It is connected to the body and I assume it should be connected to the engine. There is a very similar strap on the driver side just above and left of the brake booster, which connects to the intake manifold. Can anybody advise where that should be connected?
Thanks in advance
Re: Ground Strap Question
Post by mike-tracy »
I just worked on one of these, it was under the circled bolt.
jestermail
Thank you sir!
