Battery and Brake light
HalfNakedWalrus
Re: Battery and Brake light
Post by HalfNakedWalrus »
Thwipp wrote: Tue Apr 30, 2024 6:18 pm Have you scanned for ABS codes?
I have a scanner but nothing for ABS has ever popped up, just a 420 code :/
HalfNakedWalrus
anarchy1024 wrote: Wed May 01, 2024 8:10 am
HalfNakedWalrus wrote: Tue Apr 30, 2024 2:14 pm Alright! Calipers, rotors, pads, AND brake fluid have all been replaced. Still have a brake light.
Booo.... Might also be worth checking the handbrake switch to make sure it's not stuck on. Continuity check on the switch when it's unplugged, and voltage check when the car's on. Same with the brake fluid level switch.
I'd think if the ABS had an issue it would trigger the ABS warning light, not the parking brake light, but alternator triggers the brake light, so anything is possible.
This is golden info! I was beginning to wonder if it was something this simple! I'll look into this.
HalfNakedWalrus
The whole dang switch is gone!! the wire was just attached to the chassis!! what in tarnation lol
Uhhhh.....eh?!
Does the light turn off if the wire is disconnected from the chassis? If so, was that light on the whole time you had the truck, then? There should be a connector on the end that would go into the switch; is that gone, too?
I'm not aware of any differences in the hand brake setup between Baja years...
greymud
Post by greymud »
Just had clutch and head gaskets done. These lights are coming on sporadically for me now.
05 NA 5MT
greymud
Post by greymud »
Found loose connection on alternator - the main connection to the fuse/battery positive. Cleaned and tightened, and both lights went away.
05 NA 5MT
HalfNakedWalrus
I just installed a new switch after work today, and for the first time since I've owned it I can actually turn the brake light on and off at will.
HalfNakedWalrus
anarchy1024 wrote: Wed May 15, 2024 6:37 am Does the light turn off if the wire is disconnected from the chassis? ...
It did! that's how I found out it was a brake wire, I kept touching it to the chassis while investigating and everytime it touched the metal body the light came back on. once I looked back at the pictures of the brake switch I realized that it was just gone! There's a little nub for the switch to rest on, and that was there, which means someone at some point just removed it and just attached the wire to the chassis. The guy I bought it from claimed to be a mechanic, and that the brake light was a head scratcher for him, guess he didn't know about that little button!
Ha! Great that the mystery is solved! And that it shouldn't have been an expensive fix, either.
Guess on cars as old as ours, that have likely gone through many...diverse...previous owners (and their mechanics), can't take for granted that everything is connected properly (or, in your case, present at all).
