Restore chirp when locking door
Wishbringer
Post by Wishbringer »
My battery died and now the chirp is gone when I lock my doors. I tried the reset but I do not have the factory FOB. I have the auto start on mine. So when I press both lock/ unlock the car starts. I turned the auto start off and tried with still no luck. Any help would be awesome.
Killer B
Re: Restore chirp when locking door
Post by Killer B »
I'm not 100% certain but I think it needs to be reprogrammed into the car. Here's a Youtube tutorial on how to do it. This is for the Subaru keyless entry remote so I am unsure if different devices have different steps but you could try this and see if it works.
https://www.youtube.com/watch?v=W_u-an_GLZY
Wishbringer
I did the reset. Didn't work.
Does it still control your locks the way it's supposed to?
Wishbringer
Everything works fine the chirp is just gone. I just need to know how to reset it with the FOB I have. It is the one with autostart.
TastyHuman
Post by TastyHuman »
I apologize in advance for the dumb question.
Does your horn still work?
Wishbringer
Yes. Everything works.
Wishbringer
I just can't figure out how to reset the FOB with the autostart option.
Haha thanks for sharing my video (sometimes I regret not doing a better job recording before uploading since it's harder to go back and change it later)! Mine actually doesn't chirp either. I haven't looked into it much, but I speculate there is some little solenoid or something somewhere that isn't working. Because I've tried pretty much everything. Either that or some came with a different security module in which that was discontinued. Mine honks on the third click to tell you the security is on, but it doesn't chirp.
Was the auto start a factory option?
It's been several years since I've installed any of these but that looks to be an older Avital remote....
Wishbringer
I don't know if the auto start was a factory option. I might just order another FOB without the auto start and see if that works.
I think that would be your best bet
Pretty sure the auto start is aftermarket. They might have replaced the existing system so a new stock remote might not even work. Just a heads up.
