Who has a heated windshield?
I've been looking at diagrams, etc for my 03 baja looking to see if i can install a heated windshield in it.
It appears that the fuse is there, but not the relay or wireing for the relay.
Is there anyone on here that has one installed and working? IIRC the canada ones had the option available.
- anarchy1024
Re: Who has a heated windshield?
I have the electric wiper blade deicer, but not sure how well it's supposed to work... Since I got my Baja, I've had better luck using the defogger with high heat, than the deicer itself. So, not sure if the benefit will justify the cost/labour of installing it yourself.
Or are you referring to something else?
Can you take a picture of the pack of relays under the fuse panel inside?
You will have to put the camera under the dash and point towards the seat.
My US 03 has 3 relays, and the spot that's supposedly for the deicer is unpopulated, but the location changes based on what year manual you look at.
- anarchy1024
Sure, I'll take some pictures later today. Mine is also an 03; Canadian model.
- anarchy1024
Pictures
- 20170225_095829-2241x3984.jpg (914.35 KiB) Viewed 20639 times
- 20170225_095800-3984x2241.jpg (1.16 MiB) Viewed 20639 times
- 20170225_095640-3984x2241.jpg (1.11 MiB) Viewed 20639 times
- anarchy1024
Pictures
- 20170225_095454-3984x2241.jpg (1.13 MiB) Viewed 20638 times
- 20170225_095503-2241x3984.jpg (1.2 MiB) Viewed 20638 times
- 20170225_095625-3984x2241.jpg (1018.13 KiB) Viewed 20638 times
Thanks
Can you get one more of the this?
- 20170225_095640-3984x2241 2.jpg (1.46 MiB) Viewed 20636 times
- anarchy1024
Sure, I'll try to get that tomorrow.
- anarchy1024
I had to use the front camera to get these photos, so the quality isn't as good as the others...
- 20170305_093532.jpg (163.73 KiB) Viewed 20578 times
- 20170305_093511.jpg (105.41 KiB) Viewed 20578 times
- 20170305_093425.jpg (114.86 KiB) Viewed 20578 times
- anarchy1024
Also a diagram, if you don't have it already.
- wiper_deicer.png (14.64 KiB) Viewed 20575 times
And that confirms it... The 2003 Bajas have none of the wiring needed for heated windshield or heated mirrors.
- anarchy1024
That's unfortunate, but since the circuit is relatively simple, it should be possible to run wiring in parallel with the existing harnesses.
I retro fitted the heated windshiled as part of my color change to the STI blue.
There's two ways to do it.
The easy way. I simply tapped off the high side relay from the rear defroster. Make sure you tap the heavy wire for the deforster and not the control wire. Connect the other side to ground and you're good.
The hard way: The control module has the seperate timer circuit for the windshiled deforster built in. If you wire it to a relay and go through the trouble of adding a switch to the dash you can make it 100% factory as well.
