Under the seat subwoofer
Darthwilky
Looking for some ideas. My 2005 Baja did not come with the factory subwoofer. I also can not find any wiring to be able to plug a factory subwoofer in. What subwoofers have people used? I have a new double din and new speakers. Tweeters are not hooked up though.
- F394BA15-3C11-41B7-AA3F-2D97583483D6.jpeg (1.41 MiB) Viewed 19894 times
Re: Under the seat subwoofer
As far as i have been able to determine. The factory sub uses a factory wiring harness that follows the trans tunnel on the drivers side (N.A.) and hooks into the stereo.
I think I've seen some new OEM ones kicking around online.
J
Sent from my SM-N950W using Tapatalk
J
Leon in PA
The OEM Subwoofer harness connects between the head unit and the plug to the radio. I assume you are talking factory double din HU? I picked up a couple oem subs with harness, if you are interested let me know.
Leon
Leon
Leon in PA
IRC the tweeter wiring is supposed to be there already
I found the tweeter wiring inside the door panels, but when I plugged tweeters into them, they don't seem to work. Haven't investigated any further yet Dennis
Leon in PA
I haven't heard of that before, maybe only certain HU's powered Tweeters?ZUBAJA wrote: Sat Jul 04, 2020 10:23 am I found the tweeter wiring inside the door panels, but when I plugged tweeters into them, they don't seem to work. Haven't investigated any further yet Dennis
Darthwilky
Leon how much for a sub? I have a aftermarket head unit.
Leon in PA
$80 includes the harness. Do you stiil have the original plug on your harness?
You can double these factory subs up
dave in il
Leon, Do you still have one of these available?Leon in PA wrote: Sat Jul 25, 2020 5:39 pm$80 includes the harness. Do you stiil have the original plug on your harness?
Leon in PA
yes I do
