05 Baja Turbo, 5 Speed manual trans
11k OBO. I’m open to offers
This car has been loved and cared for by me for the last 7 years. I’m a Subaru Master Tech, and I always used Subaru OEM parts or better.
Oil changed with Amsoil 10w-40 High Zinc formula every 2500 miles. Oil analysis sent every 3rd oil change, everything is AOK internally.
Mileage is 178***, will go up daily.
Runs and drives great, no issues whatsoever. The cylinder heads have never been off this motor (original motor). It does burn a little bit of oil, maybe 1 qt every 1500 miles, but from my experience working on these motors, that’s a pretty normal amount.
Will need rear brakes and rotors soon. Front calipers and brakes are 06 WRX 4 pot swapped. I haven’t gotten around the swapping the rear calipers yet.
The car has some rust starting in the rear.
Rust is pictured, will need repaired correctly soon before rust gets too bad to be fixed.
Car is tuned (by me with romraider, factory ECU) and has all appropriate mods to make reliable power.
-Mishimoto Radiator
-Mishimoto Silicon radiator hoses
-Killer B Oil Pan, Baffle and High Volume Pickup
-STI Oil Pump
-08 STI Turbo (VF39) with ZERO shaft play
-P&L down pipe
-Grimmspeed Up-Pipe
-KS Tech Short Ram intake with 83MM MAF tube
-TGVs deleted
-Grimmspeed 3 Port boost control solenoid
-Crawford Performance AOS
-TiAL 38mm External Wastegate vented externally
-AEM A/F Gauge
-Oil Pressure gauge
-Boost Gauge
-Rear diff out of an Outback with LSD
-All subaru OEM Halfshafts
I have a bunch of extra parts to go with it. Like a ton of extra Baja parts…. 2 bed extenders, headlights, gas doors, etc etc.
Pictured the car is on steel 17” wheels with Continental Snow tires. Comes with factory Baja wheels with all seasons.
Feel free to text/call with any questions. 814-657-4528
I work a lot, so text is better to get ahold of me, but if you want to call just leave a message and I’ll get back to you.
I’m located in Venango County, PA. About an hour south of Erie
2005 Turbo 5 Speed Baja Silver
- 7C386394-7D2C-435F-901B-C32F7C47AFE7.jpeg (4.68 MiB) Viewed 6508 times
- 3C1AB52B-403B-4143-8524-1AFC5DEA1EC0.jpeg (4.44 MiB) Viewed 6508 times
- AADD751D-A4B6-4222-AF03-6E31E9EED79A.jpeg (4.64 MiB) Viewed 6508 times
Re: 2005 Turbo 5 Speed Baja Silver
Nice
