Parting out 2003 Baja. Located S.E. ohio.
ratfink
I bought this 03 without an engine. Manual trans still there and available. Pretty much a complete Baja otherwise except for the parts I needed. Let me know what you need. Thanks, Tom.
ratfink
Re: Parting out 2003 Baja. Located S.E. ohio.
Mornin greymud, I went out to the garage this morning to make sure hoist worked and to remove it from the car. Works good. Rusty but very useable. Brackets are solid enough to be used as-is. Also pulled bracket above tire. Condition not as good but useable. $50. Let me know if this will help you. Thanks, Tom
I don't need the cage, just the hoist. The cage prevents holding a full sized tire.
Does that save any $? also, including shipping? also also, venmo OK?
05 NA 5MT
I'm an old school guy, myself. I would say you should probably remove that personally identifying info from a public post. I'm a bit on the paranoid side of that, though. I'll send you a private message and get you a check.
05 NA 5MT
ratfink
I don't know how to delete my info. I sent a private message to the moderator asking for help. Hopefully they can help me. Tuesday I will ship the part out to you. I will check around for the best rate and let you know Tuesday night. Don't send the check till you get the part and make sure you are happy with it. Thanks, ratfink. (see, I'm learning.)
Does it have a bed extender? May be looking for the mounting brackets + hardware. I imagine others might be interested as well.
ratfink
Sorry Bed extender and brackets already sold. Thanks, ratfink
ratfink
THIS IS AN UPDATED LIST OF PARTS STILL AVAILABLE. SORRY I DIDN'T DO THIS SOONER. I AM SUCH A TECH DUMMY I DIDN'T KNOW I COULD EDIT MY POSTS. HOPE THIS MAKES THINGS A LITTLE EASIER FOR ANYBODY LOOKING FOR PARTS. Tom::::::::::Tons of parts still available::::::: All 4 doors including: exterior cladding, mirrors, windows, with switches and bezels. Window motors all work. (Interior panels sold).( DRIVERS DOOR IS PENDING ) $300 for all.----All 4 doors without cladding, interior panels, or switches and bezels. $200.----Door cladding. $50 each.----Switches and bezels for all 4 doors. $35.---- Plastic interior trim pieces. $5--$20 each.----Temp controls. $10.----Rear seat. $100.---- Front fender cladding and rear quarter cladding. $50 each.---- Tailgate (bare). $100. ----Window seals and trim for seals $20 per side. ---- Rear bumper cover nice. $100.----3rd brake light. $40.----Plastic inner bed panels. $25 each.----Dash (less inst. cluster) steering column, and pass. side air bag. $150.----Sun roof complete LESS motor. $100.----Rocker panels (plastic). $25 each.----Console (2 pieces). $25.----Baja mud flaps (4 pieces). $30----Wiper motor, linkage, wipers, and w.w. reservoir. $55.----R.F. headlight. $40.----Hood (a little rough but useable) with nice grill and Subaru bug shield. $150.----Trim pieces top of bed and around rear window (not complete, some damage). $50.----Relays and modules. $10 each.---- And there is still lots more odds and ends. let me know what you need. Thanks, Tom
Not that my word carries any weight, but happy customer here.
05 NA 5MT
ratfink
I'll keep things updated, ratfink
Hi! Newbie here. I have an '03 Baja that needs a driver side bed rail plastic cover. Do you have one? Thanks, in advance, Paul.
ratfink
Good evening, Sorry I didn't get back to you sooner. All this is on my home computer and I only check it a few times a day. I assume you are talking about the plastic on top of the bed that runs from the back window to the tail gate. Good news is I have the one for the drivers side. Pass side was broken. Bad news is it has holes in it because this Baja had a bed cover and there were metal pieces screwed down on top of the tail gate and both bed sides. If you plan on getting a bed cover I would be willing to sell you everything for $25. Left side plastic, tail gate plastic, and all 3 metal caps. Let me know what you think. Thanks, Tom
Hi Ratfink. Thanks for the response. I appreciate your time and effort in this, but I'd like a cover without the holes, if I can find one. Have a great Friday! 03BaPu
