Activity/sport light switch
Rizzo
Post by Rizzo »
Subarupartsforyou.com has access to the Switch and Bezel.
They have access to IIRC 18 switches and 11 Bezels.
Total with shipping was $82.51.
This is a great way to use the factory wiring harness and get a factory look for your lights you can buy else where like Amazon..
It is up to you to make sure you do NOT install lights that are of a higher volts or amps than the factory wiring was designed to handle. Things could either melt and cause a fire or shot and if that didn't happen the higher gauge wire may not deliver high enough voltage and your new lights will be dim.
Switch part and lamp part #'s
Switch H1410LS070
Bezel 66208AE36A
Here is the link they gave me.
When they're gone , they're gone!
Forever.
http://www.subarupartsforyou.com/cp_par ... rtid=23884
Hawk296
Re: Activity/sport light switch
Post by Hawk296 »
Your Bezel is upside down :P
Rizzo
Post by Rizzo »
[smilie=confuzzled.gif] :lol:
Would you mind taking a close up picture of the back of that switch?
Rizzo
Post by Rizzo »
Rizzo
Post by Rizzo »
If you push a tab on that blue piece it slides right out.
This seems to be just for alignment purposes to ensure correct connection to a specific plug.
I assume you can remove that and plug it into a different harness, Or use another switch in this harness via the same technique.
Don't know for certain.
That's what i was wondering also , i would like to use this switch but not with the factory wiring......Will have to do a little research... I think the blue thing is a lock to keep the connector from coming unplugged unintentionally...could be wrong though...anyways thanks for the pic
Rizzo
Post by Rizzo »
If I can't dig up a diagram, I can meter it out for you and find the circuit closed pins so you can just run power in and out for the switch function.
I don't exactly know how I'd go about testing or producing the ON light illumination circuit.
I bet this is the same...
Found this on All Data , Don't know if it will help anyone but figured it might....
Baja Sport Lighting.gif (24.59 KiB) Viewed 15970 times
Rizzo
Post by Rizzo »
That's awesome!
What year was that for ?
Rizzo
Post by Rizzo »
Can you find out more about the Parking Brake switch connection?
I'd like to find out what to tie together so they work without the "One Click Cheat".
05 turbo but looked the same for all years
Rizzo wrote:Can you find out more about the Parking Brake switch connection?
I will look into that for you...
Rizzo
Post by Rizzo »
awesomesauce
Can't find anything on All Data about that switch.....I've never taken mine out, do you know how many wires are going to it?
