Trouble code P0851
Trouble code P0851
My check engine light came on this morning and the Auto Zone tech said it's "neutral switch input low." Might be a loose, short, or open circuit, a failed neutral switch, or a poor electrical connection. Hey; it's a 5-speed manual. I thought only AT's had a neutral safety switch. Where might such a switch be located on a MT?
Re: Trouble code P0851
So, it looks like the MT has a Neutral Position Switch (whereas the AT has a Park/Neutral Position Switch). Diagram attached of what I think is for the 5MT.
I'll see if I can find the diag procedure for it. I remember that Part Source (and possibly AutoZone) used to print diagrams and instructions from some mechanic's software a while back. Do they still do that?
- neutralswitch.PNG (21.79 KiB) Viewed 7517 times
Diag procedure for MT.
- p0851mt.PNG (677.61 KiB) Viewed 7516 times
Wow! Thanks so much for the info. I'll crawl under there this morning and check out what I can. Knowing where the switch is, is a big help. Depending on what I find, I may have to go to a "professional" for help or part replacement. I hope it's a loose connector.
No problem, happy to help when I can. Let us know how things go.
I called an independent Subaru repair shop and they told me to bring it in; they'd check the code, reset it, and I should drive it for awhile and see if it recurs. It did, and I'll take it back next week for them to do a more thorough diagnosis.
