Tailgate Nameplate Locations
TenPA
Post by TenPA »
Had the Baja repainted and as part of that the BAJA, SUBARU, and AWD nameplates got ripped off. Could I trouble one of you to take measurements of your tailgate so I can put them back on in the same spot?
Re: Tailgate Nameplate Locations
I can take some measurements likely today or tomorrow, unless someone gets to it first, but for now here's a couple of photos of the tailgate.
"BAJA" Badge:
45mm from left tip of "B" to left edge of tailgate
117mm from top-left corner of badge to bottom of tail light recess
Lines were drawn with a laser level, and looks like the highest points of each letter are all horizontal/parallel to the ground
(See photos)
IMG_20241216_185722_906 (Custom).jpg (1.94 MiB) Viewed 128933 times
IMG_20241216_185524_333 (Custom).jpg (1.9 MiB) Viewed 128933 times
IMG_20241216_185407_750 (Custom).jpg (1.66 MiB) Viewed 128933 times
"AWD" Badge:
42.5mm from right edge of badge to right edge of tailgate
143.7mm from bottom-right corner of badge to bottom of tail light recess
Lines were drawn with a laser level, and looks like the AWD badge is perfectly horizontal
IMG_20241216_190707_314 (Custom).jpg (1.9 MiB) Viewed 128933 times
IMG_20241216_190603_037 (Custom).jpg (2.84 MiB) Viewed 128933 times
IMG_20241216_190322_812 (Custom).jpg (1.49 MiB) Viewed 128933 times
"SUBARU" Letters:
50.5mm from top edge of letters to top of metal part of tailgate, measured at the center of the tailgate (based on center of circular plastic trim piece fastener)
The top edges of all letters are coincident and horizontal
IMG_20241216_191707_841 (Custom).jpg (2.46 MiB) Viewed 128932 times
IMG_20241216_191610_161 (Custom).jpg (1.6 MiB) Viewed 128932 times
IMG_20241216_191600_039 (Custom).jpg (1.69 MiB) Viewed 128932 times
"SUBARU" Letters cont'd:
5.7mm from vertical center to bottom-left corner of "A"
11.2mm from vertical center to right edge of "B"
16.9mm from right edge of "B" to bottom-left corner of "A"
IMG_20241216_192219_475 (Custom).jpg (2.67 MiB) Viewed 128931 times
IMG_20241216_191941_798 (Custom).jpg (2.02 MiB) Viewed 128931 times
IMG_20241216_191808_296 (Custom).jpg (2.66 MiB) Viewed 128931 times
16.8mm from bottom-right corner of "A" to bottom-left corner of "R"
25.3mm from right edge of "U"(1) to left edge of "B"
22.6mm from right edge of "S" to left edge of "U"(1)
IMG_20241216_192033_004 (Custom).jpg (2.48 MiB) Viewed 128931 times
IMG_20241216_192020_915 (Custom).jpg (1.87 MiB) Viewed 128931 times
IMG_20241216_192003_877 (Custom).jpg (2.72 MiB) Viewed 128931 times
22.6mm from right edge of "R" to left edge of "U"(2)
That should be everything you need to locate the badges, right? LMK if you need anything else.
IMG_20241216_192049_885 (Custom).jpg (2.27 MiB) Viewed 128921 times
TenPA
Post by TenPA »
Wow. I couldn't have asked for better measurements and that should certainly be everything I need. That laser level looks like a nifty tool. I'll have to get one of those. I was going to make all of the edges with painters tape and expo marker but I like the lasers much better. Would you recommend the one you were using?
Love the license plate, btw.
The laser level I'm using is probably around 20 years old by now, so it's long been discontinued. Plus, I'm sure newer models will have more features than this one, but I don't have any experience with any other models yet, so can't comment on or recommend any in particular. I placed mine on a camera tripod, which made it very easy to adjust the position, and especially the height.
Thanks! My brother actually thought of it. We shared the car 50/50 back in 2010, until I bought out his half about five years later. Originally we asked for "BAJAHAHA", but surprisingly it was already taken in Ontario. I actually like the current one more, now, so I'm glad we didn't get our first choice.
One thing about the laser levels is that they are level relative to the earth, not to the tailgate, vehicle, or floor, so you may need to jack up one side to compensate.
20Baja06
Post by 20Baja06 »
anarchy1024 wrote: Tue Dec 17, 2024 6:58 am One thing about the laser levels is that they are level relative to the earth, not to the tailgate, vehicle, or floor, so you may need to jack up one side to compensate.
Phenomenal posts! Thank you for all of that information!
TenPA
Post by TenPA »
This is a great tip. I'll go look for one of those dual-axis levels. My friends give me guff about my Baja including all of the exaggerated ways they can say it. Must be a universal experience of Baja owners for another guy to have that plate.
TenPA wrote: Tue Dec 17, 2024 10:25 pm My friends give me guff about my Baja including all of the exaggerated ways they can say it. Must be a universal experience of Baja owners for another guy to have that plate.
Haha yeah, same... my old boss called it the "Bah-jah-yah-yah-hah-yah-jah-hah." Takes a bit of time giving the plate number to people, though: "B-A <pause> J-A <pause> another J-A <pause> and another J-A. Yes, that's 3 J-As. So B-A-J-A-J-A-J-A. No, the Js are pronounced like Hs because Spanish. No, it's a Japanese car. See, because it's supposedly inspired by this off-road race..."
TenPA
Post by TenPA »
It turned out great. Bought a laser level and everything. Ordered another "SUBARU" nameplate set and it came stuck to a piece of paper for easy install. The "S" is like 5 mm too low, but I figure that's within tolerance. The cardboard paper must've been bent or something.
