PCV location anyone?
w.rohr
Post by w.rohr »
I cant seem to find the the PCV location. Can anyone post a picture of the location even just a pic of the engine with an arrow to the general area would be super cool.
Thanks!
Subiedude89
Re: PCV location anyone?
Post by Subiedude89 »
PCV valve is located at the top of the block, passenger side, in front of flywheel/torque converter access panel. Hose should lead to air intake just past throttle body, passenger side
Subiedude89
Here's a diagram. To trace from the intake manifold
w.rohr
Post by w.rohr »
Ya, that is where I thought it was. Turned out there is a pressed fitting for the pcv and the pcv was so stuck I was spinning the fitting and never making headway. I stuck a wrench on the fitting but still counld not get the pcv free and was afraid of snapping it in half. I am going to see how much the local mechanic will charge me to do it.
