Fuel door falling off fix
mkwpros619
Post by mkwpros619 »
Here is a video I made on how to fix the fuel door / gas cover from falling off.
https://youtu.be/nc6nCc1m-8k
gsxrdoug
Re: Fuel door falling off fix
Post by gsxrdoug »
I might do it a little different but you got me thinking and I do worry about that door flying off and being gone forever.
Thank you.
20Baja06
Post by 20Baja06 »
I’d probably use some slip-on nuts and simply run a bolt through like the original clips. Something like these nice options from McMaster-Carr, for example.
I didn’t realize this was an issue so I’ll definitely be looking into it in the near future.
Trunc
Post by Trunc »
Mine fell off just the other day. The plastic pin on the forward side of the cover broke. I cleaned the surfaces and squeezed a small amount of silicon in and around the pin. This made “cap” on the broken pin so it will not come off. Silicone lasts virtually forever. A simple, cheap, clean fix.
Trunc
Post by Trunc »
PS- I suggest give the cover a little tug at each fuel up to find the problem before it falls off. I ended up searching the roadway for 1/2 hour before I luckily found it.
20Baja06 wrote: Wed Dec 20, 2023 5:26 pm I’d probably use some slip-on nuts and simply run a bolt through like the original clips.
I ended up doing something similar, just with regular nuts and bolts; I didn't want to cut the plastic door cover in any way.
1. Find nuts and bolts that fit, and trim the bolts to length. If you find a nut the right size, it'll fit snug inside the plastic "stand-offs" and not rotate freely.
2. Add a bit of glue or something to hold the nut in place, so it doesn't fall out while trying to install it.
3. Screw the bolts in from the outside as normal.
mark40
Post by mark40 »
I've used the zip tie method since acquiring my '06 in 2014.
20Baja06
Post by 20Baja06 »
The flaw with my plan to use the slip-on nuts was failure to consider that the “stand-offs” taper towards the mounting hole, meaning the plastic is narrower at the top than the bottom. The slip-on nuts I had on-hand were too long and would have required trimming along the corners that would be on the cover side of the stand-off.
I still like the idea but I didn’t have a great way of trimming spring steel so I replaced the original plastic push-in clips with some new ones I had in the drawer.
